Gear oil spewing!!!
Old Nov 8, 2004 | 12:10 AM
elric62285's Avatar
elric62285
Default Gear oil spewing!!!
Hey ya'll. The engine swap went great still don't have the rest of my exaust yet but that's not the problem. I drive it around a little and it's okay. I get home look under the car and gear oil is everywhere. I replaced the CV and the CV/tranny case seal. I drove it about thirty mile and it spews gear oil again only not as much and then it stops. I drive it home and one or two drops hit the ground when I park it. What's up? Thanx guys.
Old Nov 8, 2004 | 05:16 PM
casper's Avatar
casper
Default RE: Gear oil spewing!!!
Might have pinch the seal. Are you sure you wiped off the cv good before you put it in, dirt will eat the seal up pretty quick.
Old Nov 8, 2004 | 09:36 PM
elric62285's Avatar
elric62285
yeah it was a brand new joint. When I replaced the joint I put in a new seal too.
Old Nov 8, 2004 | 10:15 PM
casper's Avatar
casper
could have pinched the seal when you put it in, if you were not leaking before you replaced the cv's then it has to be something that you did. As bad as it sounds I would pull them back out and see what happened.
