header question
Old Nov 11, 2004 | 03:11 PM
ryanmills06's Avatar
ryanmills06
Default header question
i just have ordered that ceramic coated pacesetter header for my 2k neon. Can i use the stock bolts from my stock header of do I need seperate bolts? Thanks alot
Old Nov 11, 2004 | 07:44 PM
casper's Avatar
casper
Default RE: header question
I am not 100% sure, but I ordered a Kirk racing header from Modern and it came with the bolts and gasket. If it does not come with the bolts, I would got to the auto parts store and get some new ones, you don't wanna put a nice new header on and have old rusty bolts. But if you wanna use the old ones you could.
Old Nov 12, 2004 | 02:33 AM
ryanmills06
Thanks Casper for the info, what I will do is call them and see if they bolts are sent with the header...thanks
Old Nov 12, 2004 | 05:43 AM
71RoadRunner's Avatar
71RoadRunner
Your header should come with new bolts. If it doesn't you should get new ones because the heat from the engine and exhaust takes a heavy toll on the header bolts and they stretch from the repeated heating and cooling.
