99 dodge neon stops running too
Old Feb 3, 2008 | 03:32 AM
purecty's Avatar
purecty
Default 99 dodge neon stops running too
will a crank position sensor cause it to shut down? i ran it up the road yesterday real fast and hard. when i got back to my carport and shut it off, it wouldnt start for a while. like it needed to cool down? i can hear the fuel pump cut on when i turn switch on, so fuel pump must be ok i guess.i changed coil pack and it still does the same. it also misses like its not firing right, it misses real bad at times. any ideas on crank position sensor or other wise?ty
Old Feb 3, 2008 | 07:39 AM
bone33's Avatar
bone33
Default RE: 99 dodge neon stops running too
you cant just keep guessing and replacing parts till its fixed. check the codes and post them here.
Old Feb 3, 2008 | 12:22 PM
purecty's Avatar
purecty
the code doesnt come up as i know of. i tried turning switch on-off-on-off-on i hear nothing or see nothing, how do u check them? ty kindly
Old Feb 3, 2008 | 04:34 PM
bone33's Avatar
bone33
Dodgegirl rocks!
https://dodgeforum.com/m_63384/tm.htm
