Any Advice On What I Should Add
Hey everyone just wondering what i should do to the neon i just bought. my current mods are in my SIG so im going to share my plans for it was wondering if i could get some advice from you guyz
Okay so on my Shopping list is ......
AF/X ECU: $544
60mm No Restrict Throttle Body: $220
60mm No Restrict Intake Mani: $497
Lightweight Underdrive Pulley: $110
Thats pretty much all i have so far if anyone has any input or possible oppinions on how to add more torque and hp please share
Thank You
Justin
AF/X ECU: $544
Thank You
Justin
most CAI for neonsare not truecold air intakes at all. The only ture CAI would be the ones the mount away form the top of the exhaust manifold. The most common one would be an iceman or https://dodgeforum.com/m_833897/tm.htmthis would be a good base mod.
Underdrive pully is a good idea, limited slip diff is also a good idea if your going for TQ. Motermount inserts is also a good cheap mod
where are you planning on getting the TB and intake main?
personaly i think megasuirt is better then the AFX stuff
Im getting all my parts from Howellautomotive.com and moderperformance.com > i kinda just got into the Neon world ive been a honda guy forever until i got into my boys dohc turbo r/t so i pretty much get a lil of my advice from him and the rest of the neon group. what sites and parts do u recommend?
moderperformance.com is the best place but sometimes you can find the same parts cheaper.Howellautomotive.com has a bad rep of taking a very verylong time to get your order.
good read
http://www.angelfire.com/trek/iraya/...erformance.pdf
https://dodgeforum.com/m_298810/tm.htm
a bunch of aftermarket sites.
http://www.howellautomotive.com
http://www.modernperformance.com
http://www.moparpartscenter.com (2nd gen)
http://www.mopar.com (2nd gen)
http://www.mydodgeparts.com
http://www.leeparts.com
http://www.andysautosport.com
http://www.matrixracing.com
http://www.bodykits.com
http://www.bodykits.org
http://www.caraddons.com
http://www.extremedimensions.com
http://www.jcwhitney.com
http://www.kaminari.com (2nd gen)
http://www.lkqcorp.com (recycled parts)
http://www.razzi.com
http://www.rksport.com (2nd gen)
http://www.streetconcept.com
http://www.summitracing.com
http://www.edgeracing.com
http://www.dodgeparts.com
http://www.autopartswarehouse.com
http://www.grounddynamics.com
http://www.autodirectsave.com/home.asp
http://www.carxpressions.com
http://www.teamxenon.com
http://www.wingswest.com
http://www.neongoodies.com
http://www.boogerracing.com
http://www.lfsracing.com
http://www.k2motor.com cheap but can be hit and miss
http://www.ptuning.com
http://www.turbo-kits.com
http://www.extrememotorsports.com More for SRT owners
http://www.deyemeracing.com great site if your looking to shed some weight
http://www.turboneonstore.com
http://www.autovendors.net/
http://www.carbonfiberhoods.net
http://www.carbonbydesign.com
http://www.raceinspired.com
http://www.moparsupercenter.com
http://www.performancecenter.com,
http://www.vfiber.com
http://www.titanmotorsports.com
http://www.fwdperformance.com/store/
http://www.horsepowerfreaks.com/perf...rts/Dodge/Neon
http://www.ground-control-store.com/products/index.phpcoil overs
http://www.campbellenterprises.com/n...ance_parts.htm
underdrive pully might be you best opt, depending on how much$ you want to spend.
good read
