bogging problems
Old May 5, 2008 | 11:17 PM
N30N's Avatar
N30N
Default RE: bogging problems
i wish mine did that...it works fine if i start out slow but if i sit at a light or get on it then it will just cut out bad.when im at a light it cuts out quickly probably once every 15 seconds.ill take it to a garage so they can analyse it...
Old May 14, 2008 | 06:49 AM
alicia.brown@xerox.c's Avatar
so now my car just quit. it is blinking code 12,43,43,43, 55. What does it mean when it blinks the same code 3 times. I know that it is a multi misfire but i have replaced everything i can think of. the coil pack the wires the plugs all the sensors. should i think about replacing the injectors and if so does anyone know how much they cost?
thanks [:@]
Old May 15, 2008 | 06:48 AM
so i checked the injectors and it is not that either. I dont no where to go from here
Old May 15, 2008 | 07:00 AM
ok so i just looked and i seen that it could be a problem with Problem in power module to logic module interfacewhere the hell is that and how do i check it?
thanks again
