'04 Neon SXT conversion to SRT 4
Old Jun 18, 2008 | 03:57 AM
gbpackers_fan1's Avatar
gbpackers_fan1
Default '04 Neon SXT conversion to SRT 4
What do I need to change? Where can I get the parts? How much will it cost?
Old Jun 18, 2008 | 06:19 PM
Captansavaho's Avatar
Captansavaho
Default RE: '04 Neon SXT conversion to SRT 4
you could do this...or just get an idea of what its gonna cost you http://www.srt-4store.com/index.php?page=swaps
OR
Q: What do I need to get the SRT-4 engine in my 2nd Gen?
A: For the SRT-4 turbo engine, you will need the following parts:
Engine and Tranny
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Tranny, Upper and Lower Motor Mounts (the holes are larger on the the upper and lower mounts for larger bolts and the tranny mount is completely different)
SRT PCM (wont' need the bracket with 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line (from tank to engine bay)
Fuel Pump
Flex Fuel Line (from solid fuel line to fuel rail)
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + O2 Housing
Lower Control Arms (they're stronger yet the same in shape)
Sentry Key Module + Key that matches the PCM VIN number.
Radiator
Some options parts would include:
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
