Compression Test
Old Jul 15, 2008 | 03:51 PM
98neon_r/t's Avatar
98neon_r/t
Default Compression Test
Can anyone tell me how to EXACTLY do a compression dest for a 98 neon r/t DOHC? I have a general idea but i dont dont know what (or where they're at) to turn off as far as ignition...ect.
Thanks
Old Jul 15, 2008 | 04:49 PM
bone33's Avatar
bone33
Default RE: Compression Test
just pull off all the wires, take out plug, put on tester, crank engine.
Old Jul 15, 2008 | 06:37 PM
12 volt's Avatar
12 volt
first thing to do is get you engine WARM, next you can remove your cover form the starter relay (located under the hood in PDC) compress the relay while you have the compression tester hooked up. By useing you starter relay you bypass ignition and fuel to the engine.
these are only for direct compression test
google for better instructions
Old Jul 15, 2008 | 08:31 PM
98neon_r/t's Avatar
98neon_r/t
thanks,
i will try it
Old Jul 15, 2008 | 09:31 PM
bone33's Avatar
bone33
ORIGINAL: 12 volt
thanks for explaining in more detail.
