single or dual overhead cam??
Old Oct 3, 2008 | 02:53 PM
HawgDaddy's Avatar
HawgDaddy
Default single or dual overhead cam??
How can I tell if my 1999 neon is a single of dual overhead cam?
Thanks in advance.
Also, I have a motor mount going bad on the top by the timing belt assy. Easy enough for a novice to change out?
Old Dec 15, 2008 | 09:57 AM
das2123's Avatar
das2123
Check the 8th digit in your VIN#. If it's a "Y" then its a DOHC, it it's a "C" then it's a SOHC.
Side motor mount is easy to change. You will need to use a jack to support the engine.
