Neon Motors
Old Apr 25, 2009 | 10:06 PM
alechia's Avatar
alechia
Default Neon Motors
Does anyone know if a 1999 dodge neon motor fits in a 1995 dodge neon?
Old Apr 26, 2009 | 10:33 AM
Altima_wb's Avatar
Altima_wb
it should as long as they are both SOHC, or both DOHC biggest thing is to make sure all the sensor are the same most likely will have to swap sensors... although if your SOHC... pull the cam out of the 95 motor and put it into the 99 motor when you swap the 95 cam is bigger and adds a bit more power although both motors are rated at the same hp... it adds power to the 96-99s
