Lock/Unlock door mechanism
On the helper side i cannot unlock the with my key. I have removed the interior panel of the door to see what happen. I rod was loose and i have replace but it is like a mobile part is rusty and don't move. Do you know where i can have graphic of the inside door mechanism ?
Is it that the key won't turn or more of the rod not actuating the lock itself. If the tumbler is not working well I have used graphite suspended in light oil to much satisfaction although I have read locksmiths who abhore thies tradition.
So finally did it. I have removed the latch from door to see what was the problem and now it works fine. So now i look like a gentleman and can open the door to ladies.
I'm very happy to be able to fix lot of problems by myself. Do you imagine how much i would spend if i went to the dealer. They are at 80$/hre. Casper on another thread we spook about a multifunction switch i have to change. I think i'll be able to change it but a bit scarry because the airbag.
Trending Topics
Hey, I have a question, too! I'm having a similar problem with my 2002 Neon. I can put the key in the tumbler on the passenger side, and turn it with no problems. However, that's it! It does nothing with the locking mechanism. Is this a common problem? How do I fix it?
