need help
need help
so i went to get my inspection today and failed i have a fault code p0134 o2 sensor circuit no activity detected bank 1 sensor 1 i replaced 02 sensor and got 3 not readys on kmy test first one for 02 sensor second for egr sys and third for catalyst do i just need to drive it until they reset or is there a way to so this cause ive had the fault code reset already and went back and still failed any ideas would be nice car is a 98 sohc 2.0
Two ways to reset the computer. I recommend the first as it requires no tools or effort on your part other then driving.
1) Go to autozone, advance, oReilly, Napa, etc. Get them to put the ODB-II reader on your port and a) get the codes and b) wipe the codes. No charge.
2) Disconnect the + pos cable from the battery for about 1 minute. This allows the PCM to reset.
