2002 Neon Timing Belt change procedure
.. I've seen some really good information on this site.. but I want to make sure I get all the parts I need .....
So here is my Top 10 List of Questions ...................
1. Where have you guys bought the timing belt kit ??
2. What does it contain and what does it cost ?
3. Is the timing belt tensioner on the 2002 hydraulic or mechanical ? Which one is the better design ??
4. It is worth getting and replacing the tensioner bracket too ?
5. I will probably replace the serpentine belt tensioner while I am in there. Where can you get that part ? Cost ?
6. Does the camshaft pulley have to come off to change the waterpump ?
I saw that in addition to the crank pulley, the camshaft pulley has to come off to change the waterpump.. Is that so ??? I definitely want to change the pump...
7. Motor mounts on this vehicle sound like a problem. This Neon does have a thumping noise from the engine bay when you hit bumps. Which mounts are the problem ones? Right upper? Right lower? Rear? Are they hard to replace ?
8. Does the engine have to be raised to get at some of the fasteners to get to the belt ? How high ?
9. Once the belt is changed does the engine control computer need a value re-set ?
10. What are the big trouble points in this procedure ???
Thanks in advance!!!!!!!
thanks for the answers, the reason we use forums is to expand our knowledge of whatever specific task we need to do, but mostly to get opinions based on experience. It is great when a member posts step by step instructions. Therefore omitting the need for a chiltons or haynes of which are sometimes vague in explanations, thus making it somewhat difficult for those of us who are not professional do it yourself mechanics.
many forum members even answer with a link to a previous post on the topic of question. which is of great help when you are in a dilemma and need answers fast.
Regards,
Hobbsao
Regards,
Hobbsao
I too would like these questions answered. The cost of paying someone to fix your car and the cost of purchasing a new or used car is outrages, I would like to be able to keep my 2000 Neon going as long as possible. Please respond if you have the answers, I have 111000 mile on my neon and I think it be wise to change the timing belt. Thanks!
ill step up to this one although the original thread is over 1 yr old
Read First
http://i51.tinypic.com/noy244.jpg
Mech tensioner removal
http://i53.tinypic.com/23hr3o5.jpg
Hyd Tensioner Removal
http://i56.tinypic.com/nlebg4.jpg
Mech Tensioner Install
http://i54.tinypic.com/sykqiq.jpg
Hyd Tensioner Install
http://i56.tinypic.com/ra4u1e.jpg
Fig1
http://i51.tinypic.com/246kif6.jpg
Fig2
http://i55.tinypic.com/i2rk83.jpg
Fig3
http://i56.tinypic.com/157nqq0.jpg
Fig4
http://i56.tinypic.com/2uo6zh3.jpg
Fig5
http://i53.tinypic.com/2rwnxgy.jpg
Fig6
http://i51.tinypic.com/9bd37q.jpg
Fig7
http://i52.tinypic.com/4g3wb5.jpg
Fig8
http://i52.tinypic.com/2yuzw9z.jpg
Fig9
http://i51.tinypic.com/2wd7ybl.jpg
Fig10
http://i54.tinypic.com/2vrwnis.jpg
Fig11
http://i52.tinypic.com/11rzxap.jpg
Fig12
http://i54.tinypic.com/skuu14.jpg
Fig13
http://i53.tinypic.com/2eamkd3.jpg
Fig14
http://i54.tinypic.com/501yme.jpg
Fig15
http://i53.tinypic.com/2a9tso9.jpg
Fig16
http://i53.tinypic.com/2i20i6t.jpg
Torque Specs
http://i56.tinypic.com/2lvjv4x.jpg
Read First
Fig1
Fig2
Fig3
Fig4
Fig5
Fig6
Fig7
Fig8
Fig9
Fig10
Fig11
Fig12
Fig13
Fig14
Fig15
Fig16
Torque Specs
