2.0s.o.h.c head swap to a 2.4d.o.h.c
will a head from a 97 stratus 2.4dohc work on a 97 neon 2.0 sohc, if so about how many hp will it add? and what all would i need to change? tryin to get a little more power out of my hornet race car!
1995-1999 2.0L & 2.4L cylinder heads are interchangeable. Bolts right up. As the heads have different manifolds, you will need everything.
DOHC valve cover & gasket set
DOHC Intake manifold & gasket set
DOHC throttle body sensors
DOHC cylinder head
DOHC 2.0L camshafts (they are different from the 2.4L and "better")
DOHC valve train (recommend upgrade to a pt cruiser valve train)
DOHC exhaust manifold (stock unti is often cracked - consider after market header)
DOHC timing belt
DOHC tensioner (might as well get a new one while it's down)
DOHC timing cover ( I do not like them, but they are different from the sohc - your call)
DOHC pcm
DOHC engine bay harness ( or you can just extend the wiring for the coolant temp sensor)
DOHC passenger side engine mount bracket
New head bolts
DOHC camshaft sensor
DOHC cylinder head
DOHC timing belt
DOHC pcm
New head bolts
