Tires sizes
Old May 17, 2005 | 05:54 AM
nippondrifterae111's Avatar
nippondrifterae111
Default Tires sizes
Will 205/50/r15 fit stock rims for a neon, someone on the forum said they would, my stock rims are 15 inches. The stock tires are 185/60/r15.
Old May 17, 2005 | 06:21 PM
RadarLove's Avatar
RadarLove
Default RE: Tires sizes
Do you have a half inch clearance between your stock setup and the rear lateral link? If so, it'll fit. Tough to say without knowing the actual tire section width...
The stock rim width is 6" if I recall. 205 width tires are typically meant for 6.5" wheel widths, but most manufacturers allow down to a 5.5" width (not that I would do it...). The overall height is over a half inch shorter, so you won't run into problems rubbing on the spring perches.
Best of luck!
Old May 17, 2005 | 08:21 PM
mechengineer201's Avatar
mechengineer201
the rear lateral link? you mean the rear trailing arm? I can attest there will be no interference there.
