Squeeking noise under hood with blower on...help!!!
Old Nov 7, 2010 | 10:04 AM
02ESneon's Avatar
02ESneon
Default Squeeking noise under hood with blower on...help!!!
hey guys im new to this site and new to the whole neon thing since my gf just bought a 2002 Es 4cyl, im a diesel guy soo these cars are a whole new world, she loves the car and it seems like a great car soo hopefully someone can help me here, when we start the car to warm it up or really anytime the car is running and AT AN IDLE theres a squeeling noise like it almost sounds like her alternator but as soon as i take the car off and idle it goes away and it only does then when we have the heater blower running no matter on high or low it still does it at an IDLE and either shuttin the blower off and just taking the car off and idle makes the squeel go away, i was just wondering if like the inside of the alternator is like coming unwound and cant keep up with the blower running and giving that little bit of throttle helps it keep up with the blower...any ideas on what it could be?? it also makes a very quick squeel as soon as we start the car like as soon as it turns over and start it makes a quick squeek?? any help would be great..thanks
Old Nov 7, 2010 | 11:29 PM
marine68's Avatar
marine68
it is your alternator with a load trying to keep up with the use of voltage. Have your charging system checked at the earliest.
Old Nov 8, 2010 | 12:02 AM
02ESneon's Avatar
02ESneon
will get it checked tomorrow, but like i said the noise does go away the second i take it off idle or turn off the blower..is that possible causing the squeeking when i start it up also for a second?
Old Nov 8, 2010 | 12:31 AM
marine68's Avatar
marine68
yes, sometimes it is the bearings as it pushes the stator under loads and sometimes it is just the brushes. The one thing you do want to do yourself is check the belt tension and make sure all your connections at the alternator and battery are clean and tight, to eliminate a few things in finding the solution. Because batteries are not getting cheaper.
Old Nov 8, 2010 | 12:28 PM
02ESneon's Avatar
02ESneon
ill have to check does this car just have one serp belt or does it have a seperate alternator belt?
Old Nov 8, 2010 | 03:23 PM
02ESneon's Avatar
02ESneon
alternator tested fine any other idea's? i guess maybe the bearing could just be bad in the alternator but it still be charging fine..had it tested with a load on it high beams on and blower on high and it passed..soo any other ideas?? like i said the noise goes away when the blower is off and or when i take it off an idle soo i got no clue..
Old Nov 11, 2010 | 09:22 AM
bg1995redneon's Avatar
bg1995redneon
Is the vent control in the defogger position? If so, your AC is kicking on too and it may be that it squeeks when the AC kicks on/off.
Have you replaced the belt recently? Old belts sometimes squeek when put under a load. Don't use that belt conditioner crap either. Waste of time and money.
