19s or 18s
I had an 03 sxt with 18 velox vx 6 rims with 35 mm tires,the biggest size rim and tire you can fit on the stock suspension. I would suggest going with 17's with a 45 mm tire at least. Even with the stock suspension it will ride rough. So if you plan on lowering it you gotta go with a bigger tire then 35.
