Issues with radio flashing
I have a 2002 dodge neon. Recently the radio started turning itself off when the volume was adjusted. The radio will flash from a few minutes up to an hour before coming on. It flashes once pause and then flashes twice very quickly, which I thought was code 12 maybe? But I can't find anything anywhere that says that it means. It's the original radio. The only thing that I have not done yet, is pulled it out to check for wiring issues. Just wondered if it meant something before I pulled it apart.
Any help would be greatly appreciated.
Even if the radio has error codes, it will not show up on the odometer as engine and/or system error codes do for 2nd gen Neons when you do the key dance.
I don't even know if the radios even have error codes, or ways to access any error codes that may occur. but someone on this forum might.
