2000 Neon...ac only blows cold when brake is pressed
Old Jul 4, 2011 | 04:51 PM
Disciple's Avatar
Disciple
Default 2000 Neon...ac only blows cold when brake is pressed
Hi All I have a challenge for ya...
My 2000 Neon ac only blows cold when brake is pressed. it has been this way sense i bought it used..The previous owner said she had the compressor replaced.
All the ac ppl i have talked to say something in wiring buy i need a good area to start tracing or other answer as to the cause..
Thanks
D
Old Jul 4, 2011 | 09:14 PM
hemi4spd's Avatar
hemi4spd
im assuming the compressor is turning when the A/C is set to ON?
Im gonna put money the 1 way check valve isnt functioning properly and ur loosing vacuum.
you gonna need a vacuum gauge to diagnose this one and when re-assembling make sure all the vac tubes are greased so they dont leak they have to hold 8 in.Hg.
and there should be no more than a .75 in.Hg. drop on any line
Old Jul 4, 2011 | 11:16 PM
Disciple's Avatar
Disciple
yes compressor does turn but its only when brake peddle is pressed. not enough to engage brake just enough for the sensor to light lights.
where would i find a vacuum diagram for the car?
