Lost my fire
Old Nov 29, 2011 | 06:46 AM
04neonwtf's Avatar
04neonwtf
Question Lost my fire
For my 2004 Dodge Neon, on the side of my coil pack that fires plugs 2 and 3-for some reason isn't firing them,
i have tried three different coils on them, all the same, i am not getting a coil code on my code reader.
The injectors for those two work only when I'm cranking it, once it starts they don't work anymore.
I have good compression ( over 150 on all cyl.)
how do i get my fire back, someone help.
i think its a broken wire or the computer. What can it be?
It only runs on 2 cylinders. Please help!
Old Jan 9, 2012 | 08:06 PM
tjmcg3's Avatar
tjmcg3
Hello,
Did you ever solve your problem with #2&3 cylinders not firing? I am having the same problem. I initially had a different problem and changed the plugs/wires, coil and ECM. That problem is fixed, but now I have code P2305 and no fire on 2 and 3. I think it is a wiring problem, but I was interested to see what you came up with.
