03 neon transmission
Old Mar 15, 2012 | 12:10 AM
Jlow91's Avatar
Jlow91
Angry 03 neon transmission
About a month ago My 03 dodge neon started shifting weird. It would take a while to grab the next gear and would jerk really hard. After 5 miles of this it slammed hard and the engine light came on and the engine quit shifting. I saved up the 1700 to get the transmission rebuilt. 5 days ago it was rebuilt and running fine after. Today it started shifting weird again, jerked hard, and the engine light came on and quit shifting again.
The previous owner of the car said he had the transmission rebuilt about 2 years ago.
Why am I having a reoccurring issues with the transmission? I really don't want to fork out another grand or so to have it fixed....again.
Any ideas?
Old Mar 15, 2012 | 09:49 AM
bjr1a's Avatar
bjr1a
Its hard to say why you keep having issues, but do you have any idea what went wrong before?....get the code or have someone attach a scan tool and get some information about the current problem......Did the trans start shifting again after re-start?....If it did not, then that is a sign that the problem is electrical......
Brian
Old Mar 15, 2012 | 12:49 PM
Jlow91's Avatar
Jlow91
I did the key trick and it's giving me the general transmission code. P0700 or something...no if I pushed the car a few feet it would catch the gear again. Could it be a timing belt issue?
Old Mar 15, 2012 | 12:57 PM
bjr1a's Avatar
bjr1a
I would not think so, but if you took a compression check, you can rule it out..
Brian
Old Mar 15, 2012 | 12:59 PM
Jlow91's Avatar
Jlow91
Ok thank you. It's being towed to the shop sometime today. Hopefully the mechanic is fair.
Old Mar 15, 2012 | 05:37 PM
darthroush's Avatar
darthroush
Section Moderator
Did they replace the solenoid pack when they rebuilt the transmission? Sounds like that could have been the problem anyways. A shop will always want to rebuild the transmission whenever there is a problem. The solenoid pack is ~$100.
