gas leak
Old Oct 19, 2012 | 09:16 AM
1tonpig's Avatar
1tonpig
Default gas leak
I have a 99 highline that leaks at the filler neck when you put gas in it. Is there a difference in filler necks from metal to plastic tanks?
Old Oct 19, 2012 | 10:26 AM
bg1995redneon's Avatar
bg1995redneon
No. The filler neck is a separate component.
The filler neck is attached via a rubber hose from neck to tank, so there is no issue with the metal vs. plastic tank as far as the filler neck part is concerned.
Old Oct 22, 2012 | 11:31 AM
1tonpig's Avatar
1tonpig
I got a filler neck from the junk yard. As it turns out they mount different the 95 96 mount at the filler door with 4 screws the 98 99 mount with 3 screws there wasnt a 97 on the lot so dont know about that one
Old Oct 22, 2012 | 11:33 AM
1tonpig's Avatar
1tonpig
also 98 99 have a gnd strap the other didnt other than that the same. I could use 95 96 on the car but would have to change filler door.
Old Oct 22, 2012 | 01:11 PM
bg1995redneon
At Rockauto.com:
FINELINE Part # FND05 -$74.
FYI.
Old Oct 23, 2012 | 07:30 PM
1tonpig's Avatar
1tonpig
I got a filler tube from junk yard on the car and now i cant put gas in it. the tube fills up and slowly drains, any ideas?
Old Oct 24, 2012 | 09:35 AM
bg1995redneon
Did you hook up the vent pipe? That is what allows the gas to flow quickly. There should be a smaller hose going from a small connector on the side of the pipe to the filler neck top to provide pressure relief while filling your car.
