check engine light codes
Old Sep 24, 2005 | 03:34 PM
DeoN44's Avatar
DeoN44
Default check engine light codes
heres a site that tells the codes for CEL , to pull up a code, turn ur key on off position3 times, without turning car on, it should display "done" and a code will pop up
CEL=Check engine light
http://www.allpar.com/fix/computer-codes.html
i think these codes are for 2nd gens only
Old Sep 24, 2005 | 05:09 PM
PAGODA's Avatar
PAGODA
Default RE: check engine light codes
Hi there,
thanks for the Post. do you have any codes for a 2001 Neon? Thank you !!
Old Sep 24, 2005 | 05:13 PM
DeoN44's Avatar
DeoN44
what do u mean
Old Sep 26, 2005 | 11:18 AM
RadarLove's Avatar
RadarLove
The 2nd gens display the 4-digit code on the odometer. The 1st gens get 2-digit codes by the flashing CEL. www.troublecodes.net is an excellent rewource for reading trouble codes.
Best of luck!
