compmression psi
Old Sep 30, 2013 | 05:26 PM
dodge_neon_man's Avatar
dodge_neon_man
Default compmression psi
i have a 2005 dodge neon 2.0. what is the compression suppose to be. i done a cold test and it ranges from 88-92psi is that normal or is it low? thanks
Old Oct 1, 2013 | 02:02 AM
JoseyWales's Avatar
JoseyWales
thats bad..cold on my 01 neon 2 of my cylinders at 200 psi and the other 2 is at 190 psi..this was tested on cold engine..you want on less then 125 psi...warm up your engine then do the test again and see what you got..
