Motor Oil In My Radiator
Old Oct 20, 2013 | 08:35 PM
annalisa729's Avatar
annalisa729
Default Motor Oil In My Radiator
I have a 2004 Dodge Neon SRT-4 and there is motor oil in my radiator, but there is no water and radiator fluid in my oil. So what do you think is the problem? And how can it be fixed? Could it be a bad seal in the turbo that is causing it or a head gasket? If anyone knows what is going on please HELP me know how to fix it!?!
Old Oct 21, 2013 | 01:45 PM
sbhawaiian's Avatar
sbhawaiian
My 1st guess is blown head gasket.
Old Oct 25, 2013 | 11:22 PM
JoseyWales's Avatar
JoseyWales
or cracked head...seen that happend to when the engine over heats..some to most guy dont know this..but when your car over heats and you lose antifreeze ..then the motor is still warm to hot..you replace it with hot water...if you dont.. and use cooler water you'll shock the head=can cause the head to crack...
Old Oct 26, 2013 | 01:12 PM
sbhawaiian's Avatar
sbhawaiian
It's been a while but yes a cracked head will allow fluids to mix. Has the car been running hot? If so I would resolve that before thinking of replacing the head or anything else....
Old Oct 27, 2013 | 04:58 PM
annalisa729
No it never has overheated i noticed it fluctuate a little so i checked my radiator fluid level and noticed oil in the radiator but absolutely no water in my oil i just recently replaced my radiator for a new aluminum mishimoto radiator and have been pretty easy on the motor too so u thinking head gasket and what kind of gasket kit should i get? Copper?
Old Oct 28, 2013 | 02:07 AM
JoseyWales's Avatar
JoseyWales
tells me a cracked head gasket..but while you have the head off,have a speedshop check it..magna flux it for any cracks and machine the head surface flush..thats if the head checks out good..
Old Oct 28, 2013 | 08:33 PM
JoseyWales's Avatar
JoseyWales
ive been using these with no proublems and comes with new head bolts too..http://www.ebay.com/itm/00-05-Chrysler-Dodge-2-0L-ECB-MLS-Engine-Head-Gasket-Set-Kit-16V-w-Bolts-/251341463608?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2001%7CMake%3ADodge%7CModel%3ANeon&hash=item3a851e6038&vxp=mtr
Old Oct 29, 2013 | 01:16 PM
sbhawaiian's Avatar
sbhawaiian
Good price and free shipping too. Right on.....
