05 Neon 2.0 no crank no start no click
Old Nov 26, 2018 | 08:21 AM
Dave Rogers's Avatar
Dave Rogers
Default 05 Neon 2.0 no crank no start no click
Hi ,
I have a 05 Neon 2.0/automatic with 150k miles.
Currently it is no crank no start no click.
All the dash lights come on. radio, etc. NO CHECK ENGINE LIGHT self test on key turn
I had what I assume a loose ground wire on the battery. ( I would whack the ground battery post with a wrench and it would start for a few days, but now nothing.)
It was also cranking when this battery terminal thing happened, but i assume it wasn't getting enough juice.
Cleaned up the terminal, no go..
replaced the battery, no go.
cleaned up engine/body grounds, no go.
When turning the key, no dimming of the lights etc, ( radio shuts off like when starting the car)
I jumped the starter relay with a paper clip ( 30 and 86 pin) and the starter cranks like a boss.
Also, swapped the starter relay with the known good horn relay and still nothing.
Since jumping the relay turns it over, i assume everything beyond my starter , ground, etc is good.
continuity test on all grounds and power to starter ( 12v) are good.
tested all small fuses inside and out and there good.
Am i correct in assuming if i get dash lights, etc, ignition pin is good?
I feel like i have it nailed down to the Neutral sensor or the ECM.
Shifting to N vs P doesn't make a difference.
Is there actually a neutral sensor to replace or does it all get handled by the ECM?
Trying to avoid getting a new ECM for troubleshooting purposes if Im missing a ground or something stupid..
Aside from the NO CHECK ENGINE LIGHT SELF test, it acts like it is not in Park.
gave all the cables/sensors the "thump test"
Any ideas/advice internet? Any help would be greatly appreciated.
Thanks,
Dave
Old Nov 27, 2018 | 06:35 AM
Dave Rogers
--Edit: sorry, the CHECK ENGINE LIGHT DOES COME ON after about 15 sec of leaving the key alone and turned.
The red circle ( Security/AntiTheft light) is also on solid and constant. From what Ive read of this, could be caused by bad wiring to ECM or no comm to ECM or a faulty security code. ( I dont have a code reader or a security system.)
going to try disconnecting the brand new battery again and doing a full discharge of the power after work today.
I tried finding a 5v reference in what i believe to be the throttle sensor but couldn't . going to try again today now that i know a bit more about it. If ECM is bad, ( or if a sensor is shorted) , there will be less than 5v on the sensor to ground.
Apparently the 05 Neon doesnt have a neutral safety switch, but rather it is handled by the Transmisson Control Module ( TCM). It is buried in the tranny worse than your weird uncle Victor. so im hoping to avoid that.
I'm assuming the ignition pin is good since the key bounces back. Am I wrong in assuming this? Thinking out loud at this point. Oh where art thou, Internet Dodge Neon gurus?
