'04 Neon 2.0 cutting out intermittently
Old May 25, 2019 | 09:24 AM
2004 Neon SE's Avatar
2004 Neon SE
Question '04 Neon 2.0 cutting out intermittently
I had an issue pop up this while driving, when i press on the accelerator pedal, the engine would cut out/stumble. It didn't do it all the time,seems to be random. What could cause it?? No check engine light on
Old Jun 2, 2019 | 11:02 PM
Grey 2004 Neon's Avatar
Grey 2004 Neon
New Member
I did a resistance check on the ignition coil, Here are the results:
Primary resistance (Spec is 0.45-0.65 ohms)
Cyl 2&3= 2 ohms
Cyl 1&4= 2 ohms
Secondary resistance (Spec is 11,500-12,500 ohms)
Cyl 1&4= 12,000 ohms
Cyl 2&3= 12,000 ohms
