air intake systems
Old Nov 27, 2003 | 03:43 PM
showtime22's Avatar
showtime22
Default air intake systems
but is that a cold air intake or just ram air which sits over the header? i want one like hte one i made which drops in front of the battery and sits down past bumper not one over the header with all the hot air!!!</P>
</P>
Old Nov 27, 2003 | 05:28 PM
Truckxpressions's Avatar
Truckxpressions
its it just the short ram intake.
Old Nov 27, 2003 | 05:41 PM
dodgefreak's Avatar
dodgefreak
hey...will that one fit a 99 DOHC with the auto trans???
Old Nov 28, 2003 | 02:05 AM
showtime22's Avatar
showtime22
not interested in a ram air intake too much hot air!!!
Old Nov 28, 2003 | 03:18 PM
Truckxpressions
The intake is for the SOHC only
Old Nov 28, 2003 | 11:38 PM
showtime22's Avatar
showtime22
arent sohc and dohc throttle bodies in the same possition!!!!!
Old Nov 30, 2003 | 04:10 AM
71RoadRunner's Avatar
71RoadRunner
Pretty much in the same spot, but the true cold air kits are only availible for the manual trans cars due to space limitations. The cold air kits move the battery back a little and run it down in front of the battery and out of the engine compartment.
Old Dec 1, 2003 | 12:25 PM
Truckxpressions
One of your best bets might be to just get a good drop in replacement filter. Its the easiest way to mod the intake system and the gains would only be slightly less than a tru cai or sri
Old Feb 26, 2004 | 07:31 PM
johnnytsunami's Avatar
johnnytsunami
Default RE: air intake systems
So if I've got a '00 auto, is there a cold air intake I can put in it, or do I have to modify the manual one?
Old Feb 27, 2004 | 02:30 AM
71RoadRunner
No. Here is the Ice Man CAI for your Neon w/auto. transmission for the Magnum motor:
http://www.howellautomotive.com/Howe...roducts_id=216
And here it is for the non-Magnum motor:
http://www.howellautomotive.com/Howe...roducts_id=218
