03 srt-4
Hello everyone,
I really need some help. My srt4 was running perfectly fine until i decided to mess around with some headlight wires. Then all of a sudden no crank no start. Had a mechanic check it out. He said the pcm was fried. I order a new pcm programmed to my car and i deleted the skim on the pcm as well. Took of the skim module. I go to crank the car and nothing. No crank at all, all my fuses are new. I really need advice i want to get my car back up running again.My slave cylinder popped out so im waiting for a cable that needs to be replaced to bleed the clutch. But i know the car should turn over with the clutch safety switch off. Nothing.
