what spark-plug wire set...im running a bosch wire set... save me!! lol
Old Feb 21, 2006 | 03:19 PM
whyte69's Avatar
whyte69
Default RE: what spark-plug wire set...im running a bosch wire set... save me!! lol
gotcha, electrical interference it is. [8D] I understand that pretty well. I'm in the IT department and part of my job is to string network cable, if it gets too close to other network cable or electrical wires, you get a messed up signal or no signal at the other end. The way around that is to get shielded cable, but as far as I know there is no shielded spark plugs. I'm sure it's possible, but for as short as they are on the Neon, I don't see why you'd need it.
Old Feb 21, 2006 | 08:21 PM
acid_mojojojo's Avatar
acid_mojojojo
so when I order these crane or msd wires, they are not going to be the same size as the stock are they?
does anyone have a picture of what they look like installed?
Old Feb 23, 2006 | 06:07 AM
71RoadRunner's Avatar
71RoadRunner
No, they will be slightly larger in diameter than stock, but they will be the same length as the stock wires.
Here is my SRT-4 with the MSD coil and the MSD Super Conductor plug wires in black (they only come in red or black):
[IMG]local://upfiles/193/E0CAB15847464C0A8CD2AC4201A65460.jpg[/IMG]
Old Feb 23, 2006 | 03:48 PM
Customlimitz863's Avatar
Customlimitz863
ORIGINAL: 71RoadRunner
VERY NICE MAN... SO WHEN PUTTIN THE CRANES ON MY 04 NEON SXT. I SHOULD HAVE NO PROBS AT ALL?....N E ADJUSTMENTS I WOULD HAVE TO DO?....OR WILL THEY BE A DIRECT FIT?. JUST A LIL TIGHTER IF ANYTHING?
Old Feb 23, 2006 | 04:25 PM
acid_mojojojo
That looks great, and the same wires will work for the SOHC 2.0L engine I have? If so where did you get those and what part number? Thanks!!
btw, added my K&N CAI yesterday, I really like the way it sounds and it may just be mental but I swear I can tell the difference in power.
Old Feb 23, 2006 | 05:32 PM
Customlimitz863
ORIGINAL: acid_mojojojo
NOT DOUBT ABOUT IT....I REALLY CAN HEAR THE EXTRA LIL HUMMM IN MY ENGINE WHEN IT KICKS IN.....MAINLY AFTER THAT TINY LIL TROTTLE BODY CHIRP THAT IS KNOWN WITH THE K&N TYPHOON CAI'S....I GET THE CHIRP JUST OVER 2000 RPMS....BUT REALLY HEAR THE EXTRA CAI HUMM BTWEEN 3500 TILL SHIFTING...... I CANLIE... IM NOT SURE ABOUT THOSE MANUALS REDLINING.. BUT PUSHING. I GET JUST PASSED 6000 RPM SHIFT....EVEN OUTTA THIRD...I DEF SPIN A OUTA FIRST..NICE CHIRPING ...NOT AS MUCH WHEEL HOP. BUT IM LOOKIN TO HELP OUT WITH THE MOTOR MOUNTS
Old Feb 24, 2006 | 11:36 AM
acid_mojojojo
so the ones for the SRT-4 will work on the 2.0L engine?
If so is this the right part number?
http://www.car-stuff.com/performance...4&skipped=true
Old Feb 26, 2006 | 08:10 AM
71RoadRunner
The ones for the SRT-4 are the same as the ones for the 2.0L DOHC only, the 2.0L SOHC are different, their wires have a longer spark plug boot.
Here are the part numbers for each engines plug wire sets (that I could find fairly quickly):
MSD Super Conductor plug wires:
2.4L DOHC & 2.0L DOHC red: 32279 black: 32273
2.0L SOHC black: 32723
Moroso plug wires:
2.4L DOHC & 2.0L DOHC blue: 72704 red: 72705 yellow: 72706
Crane Firewire plug wires:
2.4L DOHC & 2.0L DOHC 2554121
2.0L SOHC 2554100
Accel 300+ Race Wire plug wires:
2.4L DOHC & 2.0L DOHC 7961
Old Feb 26, 2006 | 01:29 PM
Customlimitz863
Moroso plug wires:
2.0L SOHC 2554100
well. str8 up and too the point.. that's a wrap... all we need to know has just been said...thanx for the update R.R...wel that's wrap it up for us....... now if i can just get a lil more inside input on the magnum head 2.0 switch over to replace my stock sohc 2.0.. would be heaven...
