Octane Booster....?
Old May 14, 2004 | 01:20 AM
99neon's Avatar
99neon
Default Octane Booster....?
Will using this in my car actually do anything good? or is it possible it could hurt my performance?
Old May 14, 2004 | 01:50 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Octane Booster....?
In most cases you're better off just buying a higher octane gasoline.... a lot of the "boosters" have MMT and other bad things in them for your engine. There's no "free ride" when it comes to octane...[&:]
Old May 14, 2004 | 01:52 AM
JCswm's Avatar
JCswm
Didn't your new PCM tell you to use 92 octaine????
That's all you need!!!
Old May 14, 2004 | 02:12 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
BTW, I've got a couple of bottles of "104" I can sell ya.....Just kidding, just put 93 octane in your tank, there's no need for anything higher unless you're running something other than normal....
Old May 14, 2004 | 06:06 AM
71RoadRunner's Avatar
71RoadRunner
Yep, your new PCM should have said to use 92 octane minimum. It even comes with a sticker for the gauge cover and one for inside the fuel door that says the same. Using octane booster also costs more than buying the good gas to begin with. If you figure it at $.25 per gallon difference between regular 87 and 92 octane with an 11.5 gallon tank, your looking at $2.88 difference. The octane booster is usually around $6-8 per can that is good to treat 14 gallons. It is alot cheaper to just use the 92 and pass on the booster.[sm=smiley2.gif]
Old May 14, 2004 | 10:13 AM
99neon's Avatar
99neon
Thanks for the replies I'm already using 93 octane since I've put in the PCM, I was just wondering if running higher would give me any performance. I'm new to this whole performance scene so I'm just trying to get a few pointers Guess I'll save the $6 and go buy me a burger
Old May 14, 2004 | 11:14 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
For the money you'll save, you can even afford to "supersize" it!!![sm=smiley36.gif]
Old May 15, 2004 | 07:21 AM
71RoadRunner
If you want a little more out of it you could try some 100 octane unleaded Cam2 race gas.
