Where is the Flasher module on a Neon?
Old May 21, 2004 | 12:21 PM
white2k's Avatar
white2k
Default Where is the Flasher module on a Neon?
I put a shadow hitch on my White 2k Plymouth Neon. The kit came with a HD Flasher. However the instructions didn't say where the flasher is. I would like to ask the group before I buy the manual.
Old May 22, 2004 | 06:17 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Where is the Flasher module on a Neon?
Have you checked in the fuse box under the hood by the battery?
Old May 24, 2004 | 04:36 AM
white2k's Avatar
white2k
Are you just guessing or is that where it is? I don't see anything like the HD flasher that they sent me.
Old May 24, 2004 | 06:44 AM
71RoadRunner
That is the only place I know of that has flashers. There is another fuse block in the dash on the drives side, when you open the drivers side door the fuse cover is on the side of the dash. I don't recall seeing any flashers in there though, but I could be mistaken.
Old May 24, 2004 | 11:34 PM
techmanbd's Avatar
techmanbd
One way to find it is don't turn the motor on but put the key on the on position and turn on your blinker and listen for the flasher. I just did that and the flasher sounds like it is actually in the steering column.
Old May 25, 2004 | 06:18 PM
Robbiesan's Avatar
Robbiesan
in my 97 neon it's located inside a dashboad side-panel that is accessed when the driver door is open..
