will 95 coilover springs fit on 00 struts?
Old Mar 24, 2006 | 12:53 AM
neon2_0t's Avatar
neon2_0t
Default will 95 coilover springs fit on 00 struts?
Would coilover springs from a 95-99 none fit my 00?
Old Mar 25, 2006 | 01:40 AM
RadarLove's Avatar
RadarLove
Default RE: will 95 coilover springs fit on 00 struts?
Do you mean the stock coil springs? They will fit on your '00 struts and lower the car by about an inch. Nobody makes coilover sleeves (the skinny coils) that actually fit the 1st gen Neon properly. The ones you see on ebay will fit on your '00 struts (sort of), but won't offer much lowering, and are way too high of a spring rate for your stock struts - they'll blow pretty quickly...
Best of luck!
Old Mar 25, 2006 | 03:25 AM
neon2_0t's Avatar
neon2_0t
Ya the coilover sleeves they say 1-4 in drop is this true?
Old Mar 28, 2006 | 01:49 PM
RadarLove's Avatar
RadarLove
Absolutely not. They are a universal fit. The Neon's uncompressed spring height is a good 3-5 inches shorter than 90% of similar cars. Enough people have been suckered into buying them and installing them on the stock 1st gen struts, only to find out the best they can do is a 1-2" lift... You may break even on a 2nd gen. But like I said, they will blow the struts.
