97 Neon High rate springs making klunking noise
Old May 31, 2004 | 08:02 PM
jb's Avatar
jb
Default 97 Neon High rate springs making klunking noise
Hi all, I have a 97 ACR with klunking front noises coming from the front springs. It really complains when I turn the wheel. They started this chatter 6 months after installation. The only service I had was ball joints......shortly before that the noise began. I've sprayed WD40 - very little affect. Shouldn't these springs rest in some shock towers or something? Please note, wet weather seems to make it worse.
Thanks,
JB
Old May 31, 2004 | 10:11 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: 97 Neon High rate springs making klunking noise
I'm not 100% sure of this, but it is probably your struts. Lowering springs make you wear them out faster.
Old May 31, 2004 | 10:37 PM
jb's Avatar
jb
Thanks. I sure hope it's not the struts. These the Koni adjustables and can be reeeeeal expensive.
JB
