resonator box
Old Jun 1, 2004 | 05:53 AM
Tha Illest's Avatar
Tha Illest
Default resonator box
i know uve probably talked about this but i heard u gain a little sound a an extra hp or 2 by taking tha resonator box off. i heard it wasnt complicated but i was wonderin if anyone can gimmie some help cause i jus got my car and dont want mess it up already.
Old Jun 1, 2004 | 08:21 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: resonator box
Resonator box?[sm=smiley24.gif]
Old Jun 1, 2004 | 10:52 AM
moparturd's Avatar
moparturd
The resonator box is located in the drivers side front fender between the inner fenderwell cover and the engine bay. The box is held on by just a couple screws/bolts. This mod is meant for the lastest generation of Neon, 00-present. Remove the box and cut the tube that passes through to the engine bay. I cut the tube closest to the box in order to pick-up the coolest air possible from the inner fenderwell area without running anything else. It does make a difference. Good luck.
