Just installed a new tranny and....
Just installed a new tranny and cv shafts and now you drivers side shakes when you hit the gas what could this be? Its aligned perfectly and the wheels are balenced my friend said it could be the wheel bearing? Or is it a defective cv shaft?
What all did you undo to get the tranny and axles in? The passenger side has a big rubber dampener, but I don't remember there being one on the driver's side. Tranny mount bolted in properly? Control arm bushings intact? Axle shaft seated and torqued properly in the hub? Is the wheel wiggling side-to-side or up-and-down?
I replaced the drivers side cv shaft and the front end still wobbles i noticed that the passenger side cv shaft goes up and down a little is this normal or the problem? Also if the tranny was bolted up but off like 1/8th inch would this cause the front end to wobble>>>>>>>i am really confused.
Which cv shaft? the drivers side i just put the second new one in and the passenger side still wobbles a little il try loosining up all the tranny bolts and remounting it again and see if this works.
I'm going to have to agree with RadarLove.....sounds like a bad/bent shaft. Another thing to check would be all your mounts. If something is out of alignment or isnt properly bolted up, you'd get the vibration.
ORIGINAL: neon2_0t
