1st Gen With SRT-4
Old Apr 12, 2007 | 11:26 AM
das2123's Avatar
das2123
Default RE: 1st Gen With SRT-4
It has to be modified, but it can work.
Old Apr 12, 2007 | 11:54 AM
boczo777's Avatar
boczo777
what kind of modifications?? disc only or plate too??
Old Apr 12, 2007 | 12:11 PM
das2123's Avatar
das2123
This is some of what is involved.
ORIGINAL: JeffB#2
The first part of the work involves reducing the overall diameter to fit inside the "Neon" bellhousing.
The second part of the work is removing material to make room for the flex plate starter gear to fit to the back side of the flywheel. I had a fixture made to go into the lathe to accomodate the work that needs to be done. The flywheel bolts to it and then the cuts are made.
JeffB#2 does the conversion for $100, but you have to supply the SRT-4 clutch. There is someone in the 1st gen neon section that has one for sale.
Old Apr 25, 2007 | 07:40 PM
silverblacksrt4's Avatar
silverblacksrt4
just buy a ****ing srt4... quit trying to be an srt4.. buy one!
Old Apr 25, 2007 | 07:52 PM
das2123's Avatar
das2123
ORIGINAL: silverblacksrt4
But they are fugly
Old Apr 26, 2007 | 06:34 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: DaJokerx2
Thanks for the compliments. Radarlove..come visit and take it for a drive :-)
I just put in new rear brake hard lines, fuel supply an vapor lines. Swapping in a non abs disc/disc booster and cylinder to get more room in the bay ..should be able to turn my filter under the cylinder.
Just put in the srt p/s lines and test fitted the pump today..also got a ton more coated parts..solid fmm & bracket..throttle linkage, p.s, ac bracket etcs..icemna tie down matched to vc
pic
Sorry for the jacking :/
Later
Jake
any way to get the intake into the fender to have true cai??? looks liek the only way to do it would be to relocate the battery eh?
Old Apr 26, 2007 | 11:37 AM
das2123's Avatar
das2123
ORIGINAL: flamingpinhead
ORIGINAL: DaJokerx2
Yep I have! I'll be picking up a smaller kit made for the srt4 this year sometime.With the battery kitand another secret mod I'm working on I can clean up the wiring more, hide the pcm and run a true cai.
Posted on 3/22/2007 6:15:26 PM
Old May 9, 2007 | 11:34 PM
Extatique2005's Avatar
Extatique2005
I've got a 98 Neon coupe that Im trying to basically turn into an srt4. Ive got the complete engine, ecu, engine harness, intercooler.....Im going to need some help, and Im wondering if there is anyone in Washington state that has already done the complete swap and wouldnt mind coming over to lend a hand?
Ive put together my 03 srt4 from the ground up, but Ive never tried swapping a 1st gen. Im lost! lol
Old May 10, 2007 | 01:04 AM
das2123's Avatar
das2123
ORIGINAL: Extatique2005
https://dodgeforum.com/m_746808/tm.htm
Old May 10, 2007 | 02:43 AM
Extatique2005
thanks for that link....it will be very helpful.
I just acquired EVERYTHING to make an srt4 (electrical, mechanical, full interior) about a half hour ago. So basically I'll only be using my 98 shell in place of the srt body.....that should make things ALOT easier. Id still like some help on the wrench time if anyones in the area and willing.
