RPM Limiter !!!
Old Jun 6, 2004 | 06:24 PM
sexualwhitechocolateneon's Avatar
Default RPM Limiter !!!
is there a way to remove the rev limit on the neon, 02 se 4 door auto to be exact. when you put the car into neutral and rev, it seems to goto about 3 maybe 4-5 thousand and then it cuts off. wont let you rev any higher. there's got to be a way to take that limiter off and or change the max setting on it ???
Anybody !?!?!!?!?
Old Jun 6, 2004 | 06:30 PM
JCswm's Avatar
JCswm
Default RE: RPM Limiter !!!
Why do you want to rev the engine up that high with no load????
To answer your question, I have not seen a way to bypass the rev limiter, It's part of the programming!!!!
Old Jun 6, 2004 | 07:24 PM
just want to be able to have that power to use when i need it !!!!. rev a little higher to about 5-7 thousand then throw in gear and seeya ..................................( yes it's still a neon, i know ) i just want to know for my own info and also be able to move when i need to. !!!!
Old Jun 6, 2004 | 10:25 PM
dodgemech's Avatar
dodgemech
No, you cannot remove/change, or modify the factory rev limiter. A neon isn't staying together long at 5-7K anyway-not to mention its WAY past its peak power by then.
Old Jun 6, 2004 | 11:25 PM
LowSlowNeon's Avatar
LowSlowNeon
It should rev past 3-4K even 5K, should go to redline, but it will only go so high because the camshaft in addition to a computer will tell you when you're done reving.
Old Jun 7, 2004 | 11:02 AM
71RoadRunner's Avatar
71RoadRunner
If you bring the RPM's up that high and slam it into gear, the only thing your going to be doing is picking up transmission peices off the ground provided some of it doesn't come through the firewall and send you to the morgue. Even if it did hold up, which it wouldn't, all you would be doing is sitting there spinning your tire.
Old Jun 7, 2004 | 10:35 PM
ok ok. !!! Thank You, i now know that i can't be doing anything like that ........ i do understand now what would happen and why there put that limit on there . BUT why is it that a honda can rev like crazy ?? new and old ???
Old Jun 7, 2004 | 11:23 PM
LowSlowNeon
Not all honda's can rev like crazy. What you are probably referring to is honda's with Vtec, aka, Variable valve timing and lift electronic control. Basically what it does is smooths out the power curve. It's basically meant for gas mileage because most people drive at low rpms but it allows for making high power at high rpms because at certain rpm the computer changes the cams timing. So its kinda like it has a low speed camshaft and a high speed camshaft. Hope I got that basically right, and that it helps.[sm=smiley17.gif] I'm still waiting for the day when i can run a stock Civic with vtec, see who takes that one, the driver would be the difference in that race.
Old Jun 7, 2004 | 11:31 PM
dodgemech's Avatar
dodgemech
Hondas dont have revlimiters in their software package.
Old Jun 8, 2004 | 06:17 AM
71RoadRunner
Yep, it's the V-Tech thing. They have to hit 9,999,999,999 RPM's[sm=smiley36.gif] before they even start to produce any power.
