2000 DODGE NEON TIMING QUESTION
Old Jun 14, 2004 | 12:25 AM
tyson724's Avatar
tyson724
Default 2000 DODGE NEON TIMING QUESTION
WHAT HAPPENS IF MY TIMING IS OFF BY 1 TOOTH ? PLEASE HELP
Old Jun 14, 2004 | 12:28 AM
tyson724's Avatar
tyson724
Default 2000 NEON ES WITH RT CYLINDER HEAD
I INSTALLED AN RT PERFORMANCE CYLINDER HEAD ON MY 2000 DODGE NEON ES. IT SEEMS NOW THAT I HAVE LOST SOME HIGH END RPM'S. WHY ?
Old Jun 14, 2004 | 04:28 AM
Aricjm15's Avatar
Aricjm15
Default RE: 2000 NEON ES WITH RT CYLINDER HEAD
as a general rule
when you advance the timing of your cam, you power band moved DOWN in the rpm range, so your engine would make its maximum power SOONER
when you retard the timing the power band moves UP in the rpm range
on the SOHC engine it makes the best power when the timing is dead on, not advanced not retarded
I have a R/T engine in my 96 and it still pulls all the way up to 6500
