DO I NEED MORE FUEL ???
Old Jun 16, 2004 | 02:45 AM
tyson724's Avatar
tyson724
Default DO I NEED MORE FUEL ???
I HAVE A 2000 DODGE NEON WITH ALL THE BOLT ONS, I JUST PUT ON A IT R/T PORTED CYLINDER HEAD. NOW I SEEN TO LOOSE OUT ON HIGH END RPMS? WHY? DO I NEED MORE FUEL ?
its a ported it r/t neon head with crane cam (nitrous profile)
race performance pcm
head back full exhaust system
60mm tb
iceman intake
underdrive pulley
Old Jun 16, 2004 | 03:18 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: DO I NEED MORE FUEL ???
You running the stock intake manifold? Cause if you are, it could be holding you back.
Old Jun 19, 2004 | 03:44 AM
brightwhite95sport's Avatar
brightwhite95sport
this is what i did..
I changed to Accel fuel injectors 21lb
from the stock 19lb
My engine had the stock injectors
working overtime. Run to rich they were in safe mode
because of not enough fuel.. There is a 10% range above and below what it uses on stock ,I think if you
go past that it goes nuts.
IceMan with Xtreme K&N air filter
AEM Adjustable Cam Gear
Mopar Performance PCM
MSD Ignition Coil
Magnecor Sparkplug wires
MPx Billet Aluminum Throttle Body 55mm
Crane Valve Springs and Titanium Retainers
Crane Cam Street Performance with Nitrous profile
Kirk Racing Header
OBX Bomber Exhaust
Stainless Steel Resonator
NO Cat
Ported & Polished Head
Balanced Crank
Borded 20 over
Flat Top pistons
Old Jun 20, 2004 | 09:22 AM
71RoadRunner's Avatar
71RoadRunner
Since you have all this done to it you should also get the Indy intake manifold for it, it's alot better than stock. Plus it is a 2 piece that you can do alot more with as well. Don't forget to upgade the ignition as well.
Old Jul 6, 2004 | 10:21 PM
brightwhite95sport
I have a SOHC so the manifold is smooth, also I have a Mopar Performance PCM &
MSD Ignition Coil.
Old Jul 6, 2004 | 11:11 PM
red91RT's Avatar
red91RT
yep, had the same problem before. It's running too lean from the O2 sensor perception because injector can't keep up so it enrichens it beyond the long term and short term maps and you get MIL indicators. Starts running crappy. I was able to reset, run good for 100 miles (couple starts) and then it run crappy again with the MIL back on. Didn't think it was a common problem to see that--mine caused by first rebuild I did in which . . . well long (and embarrasing story--never mind).
Old Jul 16, 2004 | 12:11 AM
tyson724's Avatar
tyson724
i reset all the setting and the car is running better now. i still think i need more fuel. i tried 24lb accel injectors and they leaked like crazy ? why ? all new seals .. they seemed to tall for the stock set up
