Who's got it?
Old Jun 16, 2004 | 03:48 AM
LowSlowNeon's Avatar
LowSlowNeon
Default Who's got it?
Okay, so I just ordered the mopar short throw shifter. Who's got this bad boy installed already? How is it? Anyways, I will have it by the end of the week, should be installed this weekend. YAY![sm=smiley20.gif]
Old Jun 19, 2004 | 10:56 PM
Soccerneon's Avatar
Soccerneon
Default RE: Who's got it?
I do not have the mopar short throw, but i have installed a short shifter. Some times it scares me how fast i can put it in gear. The one thing i dont like about the short shifter is the diagonal shifts 2nd to 3rd only because there is little neutral room so it takes some practice. But i think you will like your short shifter.
Old Jun 20, 2004 | 08:50 AM
71RoadRunner's Avatar
71RoadRunner
It's frickin' great!!!! I put mine in my SRT-4 friday and it is a world of difference. Sharper, more positive shifts with way less throw and a really solid feel. It is an easy install as well, except the black clips that retain the shift cables in the bracket/housing. These things are a real *****. Bildo had a great suggestion that should get this done perfectly well and easy, use the claw end of a hammer to pry them out. My only negative comment about the Mopar STS is that it is a bit stiff, it should loosen up after a little use though. I believe that the SRT-4 STS and the other newer Neon STS's are the same, but the non-SRT-4 Neon's require the SRT-4's shift **** and shift boot.
