help with header and high flow cat
Old Jun 25, 2006 | 09:50 PM
soldier's Avatar
soldier
Default help with header and high flow cat
ive been thinking about buying a header and highflow cat off of ebay. which is better a ceramic header or steel header?
[IMG]local://upfiles/38042/27A0276615AD4F5CB8A87B7E7E3174DE.jpg[/IMG]
[IMG]local://upfiles/38042/879A1482B5E04572A60A9EB04B5EB86D.jpg[/IMG]
Old Jun 27, 2006 | 06:49 PM
das2123's Avatar
das2123
Default RE: help with header and high flow cat
Steel is heavier and prone to rust, ceramic would take longer to rust. You don't need a high-flow cat unless you are pushing out some serious HP. Don't waste your money on either until you make it breathe better first.
Old Jul 2, 2006 | 10:21 PM
bouda's Avatar
bouda
Ceramic is just a coating on the the steel to reduce underhood temps. Isn't it?
Old Jul 3, 2006 | 01:34 AM
das2123's Avatar
das2123
ORIGINAL: bouda
Yes, sory I didn't make that clear, but also helps prevent corrosion.
Old Jul 3, 2006 | 03:02 AM
darianlow's Avatar
darianlow
Where did you get your headlights. Mine are all crappy now, yellow and scratched and ugly
Old Jul 3, 2006 | 12:13 PM
das2123's Avatar
das2123
Me? They are the Diamond clears from Modern Performance. $130
http://www.modernperformance.com/dcx..._1995-99.shtml
