How To Install Tach on Base 2000 neon
Old Jun 28, 2004 | 11:45 PM
ryanmills06's Avatar
ryanmills06
Default How To Install Tach on Base 2000 neon
Can anyone help me how to install a tachometer on a base neon that does not come with a tachometer in dash..Please Help..thanks
ryan ...2000 plymouth neon
Old Jun 29, 2004 | 09:12 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: How To Install Tach on Base 2000 neon
Are you trying to install a factory gauge cluster that has a tach or are you adding a seperate aftermarket tach like an Auto Meter?
Old Jun 30, 2004 | 12:55 AM
moparhoney's Avatar
moparhoney
Perhaps his question was answered....
Old Jun 30, 2004 | 11:52 AM
ryanmills06
The tachometer that i need to install is a aftermarket tach..like an autometer tach..The problem is i dont know where the negative coil is .that is where it says i need to attach the wire connection to. I have all other connection done correctly. This is the last piece i cant figure out..thanks
Old Jun 30, 2004 | 12:06 PM
71RoadRunner
Do you have the tach adapter AKA: tach driver, you will need it since it is a distributorless ignition.
Old Jul 1, 2004 | 04:53 PM
ryanmills06
yeah, i do have the tach adapter, but now my problem is finding where to install the tach driver too. I have no clue??? Thanks again for your help..
Old Jul 1, 2004 | 05:44 PM
moparturd's Avatar
moparturd
There are 2 or 3 wires going into the coil pack on top of the engine. The wires hook up to those. You need to consult the directions or the manufacturer for the specific wires. Good luck.
