noise starting at 45-60 mph ?????
actually it sounds like the noise my engine(on enother car with mechanical gear box) was making while descending the hill. I mean the car was slowing down mainly by gear box not brakes. noise is almost similar. it doesnot metter i am pushing accelerator or not it is most annong during deceleration
check your front end components....jak up the front of the car and see if the wheel wobbles.....there shouldnt be any movement...but if there is then sumthing needs to be changed
See if it changes while steering side to side. If it does then it probably is a wheel bearing however have had a few CV shafts get me with similar noises over the last year or so.
