98 neon cai
Old Jul 7, 2004 | 03:06 AM
98neonsport's Avatar
98neonsport
Default 98 neon cai
I have a 98 dodge neon DOHC. Are there any intakes made for my car? The Aem intakes for the year and DOHC motor say they can only be used on the 5-speed w/o abs. My car is a automatic transmission and has abs. The Injen intake is only for the newer models. The K&N intake are for the SOHC motor only. Also I was wondering if an aftermarket intake on a 98 neon takes the place of the old intake or if it is positioned down under the left fender instead of back behind the engine.
Old Jul 7, 2004 | 06:34 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: 98 neon cai
It would appear that your screwed then. But I have heard that you can use the Iceman or Mopar CAI's, they're the same thing, and simply shorten the pipe a little on the filter side to get it to fit right on an auto DOHC. Check around about it first, this is just what I have read. You might want to call some place like Modern Performance and ask one of their techs about it.
Old Jul 8, 2004 | 02:23 AM
98neonsport
I checked about that and found out that you were right and that a iceman intake will work if i shorten up the pipe a little. Thanks for the help.
Old Jul 8, 2004 | 07:38 AM
71RoadRunner
Not a problem, glad to be able to help you out.[sm=smiley20.gif]
