More H-Power
Old Jul 17, 2004 | 06:31 PM
Christeen's Avatar
Christeen
Default More H-Power
Any one think it would be smart to go ahead and replace the Throttle Body ,Intake Manifold,Header,and get larger piping than factory with a Magflow ,and get an after market muffler? And all this to gain what i hope would be a lot of HP.All this for a 2000 neon ES.
Old Jul 17, 2004 | 06:50 PM
casper's Avatar
casper
Default RE: More H-Power
rule of thumb is balance the amount of air comming and going out. If you put all those intake componts on, you won't gain much hp unless you have a good cam, exhuast manifold, no or hi-flow cat and a good muffler.
Old Jul 17, 2004 | 09:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Be careful with the "aftermarket muffler"....if you lose too much back pressure, you'll lose low end power. Shop around for a "tuned" exhaust system for your car....
Old Jul 19, 2004 | 01:00 PM
KlerricK's Avatar
KlerricK
Or check out the R/T style exhaust.
Old Jul 21, 2004 | 03:44 AM
Christeen's Avatar
Christeen
So what would you do if you were me and buying a different car in not an option ?
Old Jul 21, 2004 | 03:46 AM
Christeen's Avatar
Christeen
What would you do then ?
Old Jul 21, 2004 | 03:47 AM
Christeen's Avatar
Christeen
Do you think that would work for me ?
Old Jul 21, 2004 | 04:03 AM
Christeen's Avatar
Christeen
What to do then ?
Old Jul 21, 2004 | 01:13 PM
Altima_wb's Avatar
Altima_wb
To tell you the truth you are not going to gain much of anything without installing a cam. Here is the direction I would recomend taking:
1: Crane cam grind #12 (don't forget the springs)
2: AEM cam gear (same time as step one)
3: Iceman CAI or someother brand (Make sure its a CAI)
4: One of the catbacks (Pacesetter, borla, thermal R & D)
5: Header (pacesetter, Kirk racing, Borla, Stay far away from OBX)
6: High flow cat
7: Underdrive pulley
8: INDY intake manifold
9: Larger TB
10: Prothane motor mounts
11: MSD coil
12: Magnacor 8.5mm wires
13: NGK or Denso Iridium spark plugs
14: AFX computer
Any of those steps can be changed around to what ever you like but I highly recomend you do all those first before moveing on to the next step which is Turbo. Both Chill factor and Hahns make a turbo kit for you car. Both of them are great setups (most people seem to think the chill factor is better). If you ever get this far make sure you save the extra coin and get the intercooled kits.
Hope this helps!
Old Jul 23, 2004 | 02:53 AM
03sxt's Avatar
03sxt
Altima_wb how come stay away from OBX headers?
