How the #*(# Do You Get The Headlight Out?!?!?!
Old Mar 14, 2005 | 02:23 PM
gabesn200sx's Avatar
gabesn200sx
Default RE: How the #*(# Do You Get The Headlight Out?!?!?!
It's much easier to remove the two screws that hold the intake in place and move the intake filter out of the way to reach behind the lamp housing. It's quicker that removing those two screws. Safer for the headlight you are replacing as well.
Old Mar 14, 2005 | 06:24 PM
jonbonazza's Avatar
jonbonazza
Nope you can't Amanda, at least on the drivers side light. Anyways to take the light out you have to undo obviously the two screws that hold the headlight in. Then after that there should be I believe 3 fascia screws/clips that hold part of the bumper down that you need to take out. Then you will need to pull back on the bumper a little bit then its just a matter of pulling the headlight out, its a PITA (pain in the ***) because there is a huge chunk of plastic that sticks into the frame, I was considering just hacking it off because it was annoying as hell. Anyways thats how you do it, hope that helps.
ACTUALLY i changed my bulbs without taking the headlight out.. i just took part of the airbox out and reached down there as for the other side u just need small hands =)
Old Mar 14, 2005 | 06:34 PM
LowSlowNeon's Avatar
LowSlowNeon
Holy OLD THREAD. But yes, I've heard of that from other people as well. Unfortunately, my hands don't fit in that small of space. I've tried, and I have taken my air box out and I still have to take the headlight out to change bulbs.[:@][:@]
Old Mar 14, 2005 | 07:36 PM
casper's Avatar
casper
wow thats crazy, all that to replace a bulb.
Old Mar 14, 2005 | 09:04 PM
RayDog26's Avatar
RayDog26
yeh tell me about it the design is really horrible.... make sure u take it out tho cuz i wrecked my set of bulbs that way... i tried to "make" them fit through all the lines and Sh*t in the way and i ended up getting dirt on the bulb and they blew out as soon as i hit the headlight switch......wasted cash......sigh...
Old Mar 14, 2005 | 09:14 PM
SXTNNY's Avatar
SXTNNY
MAN I started this thread sooooooooooooooooooooooooooooooooo long ago!!
Oh and give me my Avatar back!!
Old Mar 14, 2005 | 09:35 PM
RayDog26's Avatar
RayDog26
UR AVATAR !!! its mine now [sm=laughat.gif]
lol[sm=icon_cheers.gif]
Old Mar 15, 2005 | 02:23 AM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
ORIGINAL: Dodgegirl19
Wow... that's crazy...
I logged into Dealer Connect and this is what it says:
1. Disconnect and isolate the battery negative cable.
2. Remove two screws attaching headlamp unit to upper crossmember.
3. Remove three screws attaching fascia to radiator crossmember and carefully bend fascia forward to allow removal of headlamp unit.
4. Remove headlamp unit from vehicle.
5. Disconnect wire connector from back of headlamp.
6. Rotate retaining ring counterclockwise one quarter turn.
7. Remove retaining ring from headlamp unit.
8. Remove bulb from headlamp unit.
I removed, replace and re-attatched in 5 minutes. It's not as hard as it seems.
Old Mar 17, 2005 | 01:23 AM
ewetho's Avatar
ewetho
Pasenger side easy as others have said. Driverside is harder but even with my non Japanese Meat Hook I can get the bulb in and out with just the top of the air box off. No real biggie you just ahve to want it.
