How the #*(# Do You Get The Headlight Out?!?!?!
Old Jul 18, 2004 | 04:37 PM
SXTNNY's Avatar
SXTNNY
Default How the #*(# Do You Get The Headlight Out?!?!?!
OK, pretty much what it says. 2004 Neon and I want to change out the signal lights for the Silverstars. Problem is I have no idea how the hell you get the headlight out to do it. I know you take the two LONG screws out...then what? The plastic mounting bracket on the inside is in the way. You can't pull it "straight out" like the book says either. OK, it's a simple thing and it's driving me NUTS!! Any help or ideas?
Old Jul 18, 2004 | 05:31 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default RE: How the #*(# Do You Get The Headlight Out?!?!?!
Can't you take the headlight bulb out through the back of the headlight... in the engine compartment... ? You don't need to take the whole headlight out to change the bulb...
~Amanda
Old Jul 18, 2004 | 09:21 PM
LowSlowNeon's Avatar
LowSlowNeon
ORIGINAL: Dodgegirl19
~Amanda
Nope you can't Amanda, at least on the drivers side light. Anyways to take the light out you have to undo obviously the two screws that hold the headlight in. Then after that there should be I believe 3 fascia screws/clips that hold part of the bumper down that you need to take out. Then you will need to pull back on the bumper a little bit then its just a matter of pulling the headlight out, its a PITA (pain in the ***) because there is a huge chunk of plastic that sticks into the frame, I was considering just hacking it off because it was annoying as hell. Anyways thats how you do it, hope that helps.
Old Jul 18, 2004 | 09:31 PM
Dodgegirl19
Lady Administrator
Wow... that's crazy...
I logged into Dealer Connect and this is what it says:
1. Disconnect and isolate the battery negative cable.
2. Remove two screws attaching headlamp unit to upper crossmember.
3. Remove three screws attaching fascia to radiator crossmember and carefully bend fascia forward to allow removal of headlamp unit.
4. Remove headlamp unit from vehicle.
5. Disconnect wire connector from back of headlamp.
6. Rotate retaining ring counterclockwise one quarter turn.
7. Remove retaining ring from headlamp unit.
8. Remove bulb from headlamp unit.
Crazy, crazy...
~Amanda
Old Jul 18, 2004 | 09:33 PM
Altima_wb's Avatar
Altima_wb
Who ever came up with that design should be drug out in the street and kicked. Damn engineers don't think about the people working on cars.
Old Jul 18, 2004 | 09:40 PM
Dodgegirl19
Lady Administrator
I fully agree... I cannot believe it takes that much effort... thats why I logged into DealerConnect to doudble check... I'm stunned...
~Amanda
Old Jul 18, 2004 | 09:43 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Thank goodness the taillight swap on my SRT-4 was a piece of cake.....!!!!
Old Jul 18, 2004 | 09:58 PM
LowSlowNeon
And I should add that its easier if someone pulls back on the bumper a little while the other takes the headlight out. Thats how I did it, I really would of had a hell of time getting it out doing it completely by myself, its a snug fit.
And by the way, the owners manual directions are useless for taking out the headlight. Its so vague, plus it makes it sound like its easy, which its not really.
Old Jul 19, 2004 | 12:53 AM
sauceboy's Avatar
sauceboy
i fully agree. i damn near took my car back on account of it being such a pain in the *** to change to headlights! (not really) changing the fog lights are nasty too. if you're gonna do that, i highly reccomend jacking it up or a lift or something.
Old Jul 19, 2004 | 03:05 AM
SXTNNY's Avatar
SXTNNY
Ya..I noticed is was a PITA when I put my Silverstar headlights in. I pulled the lamp out as far as I could and weadged my hand in to get the bulb out and in. I could have screamed. I took all those clips and screws out cause I figured I'd have to in order to get the damn thing out. I still couldn't do it. I really think you need two people for this. What a major pain. It's one thing I can't stand about the front end. What was the guy thinking when they designed this?! That's one good hting I will say about my last car. 2001 Grand Am. The lights were a breeze to change.
At least the rear lamps were VERY easy to swap out for the Mopar Custom Tumer Tails.
Well, I guess I'll have to get somebody to "help" me change the bulbs......man I feel like a loser. haha
