NEON TRUBLE HELP~!!!!
Old Jul 22, 2004 | 03:13 PM
fastcobraII's Avatar
fastcobraII
Default RE: NEON TRUBLE HELP~!!!!
i actualy only looked at one of the fuses, what are the other fuses that could be bad? is there more than one? and how do i run the pcm through its self diagnostics? thank you very much for the help. Sry for the confusion of my first post i was in a masive hurry.. thank you much
~S.R.T.~
~Shannon Ray Torvinen~
Old Jul 22, 2004 | 06:45 PM
casper's Avatar
casper
To ring out the code, I am not sure what the order is, but you have to turn the ignition on and off a few time in a cetain order and the check engine light will flash out the code your best bet is to go buy a service manual at a local auto store, like $14. that will give you the way to ring out the code and all of the codes.
Old Jul 22, 2004 | 06:53 PM
vettegofast's Avatar
vettegofast
I think autozone does free diagnostics.
