HELP! My neon sucks
Old Aug 10, 2004 | 07:40 PM
  #21
casper's Avatar
casper
Default RE: HELP! My neon sucks
That whole high beams thing is the funniest thing I ever heard!!!!! Just hold the lever back as long as you want the high beams on its that simple or just push it forward and drive with 2 hands, lol
Old Aug 17, 2004 | 01:10 AM
  #22
Raven18940's Avatar
Raven18940
Ok, it's the gauges dropping the zero, the dash remains lit. Someone said it was a solder joint problem, how do I fix that?
Old Aug 17, 2004 | 01:18 AM
  #23
Cr@zy Squ33's Avatar
Cr@zy Squ33
Check and reflow those pins inside the yellow circles. Just be careful. You don't want to push the pins out of the board. Then you'll have to resolder the whole thing.
Old Aug 17, 2004 | 10:05 PM
  #24
Raven18940's Avatar
Raven18940
uhhhhhhh, "check and reflow"? Not quite clear on the lingo. You mean resolder things that aren't connected. And how exactly do I check these connections?
Old Aug 17, 2004 | 10:09 PM
  #25
Cr@zy Squ33
The solder points are called flows. Follow the flows and reflow the ones that look bad. Just be sure to be careful when doing so. YOu can usually tell the good ones fromt he bad ones, when they are bad they are discolored or "cooked" off.
In order to reflow them you are going to need a soldering iron.
Old Aug 17, 2004 | 11:36 PM
  #26
Raven18940's Avatar
Raven18940
OHHHHHHH, I get ya. Thanks, you're the man!
Old Aug 17, 2004 | 11:54 PM
  #27
Cr@zy Squ33
No problem.
Old Aug 18, 2004 | 01:27 PM
  #28
Altima_wb's Avatar
Altima_wb
Hmmm, I might have to check in to that. Project neon seems to have developed some kind of odd electrical glitch.
