Need help-95 neon highlin
<IMG src=smileys/smiley5.gif border="0"> ? anyone have any ideas on where to go next. Car will not start, turns over but will not catch. Have changed plugs and wires, cam sensor and coil pack. Told to check asd relay and pcm-all fine. Car getting spark at plugs and coil pack and getting fuel. Need help!</P>
If you have already established that the plugs are firing and the injectors are functioning properly, then it has to be a timing issue. You might want to check/replace your crankshaft sensor. Other than that, the only thing I can think of right now is the timing belt. If the catalytic converter is completely plugged it wouldn't run, although this is highly unlikely.
Already changed the crank sensor. Will have the timing belt checked. Have been told by several mechanics to check the asd, pcm but no one knows how to test them. This is my daughters car that is sick <IMG src=smileys/smiley11.gif border="0"> and mom is tired of playing taxi! Will try the timing. Thanks
Trending Topics
